Go to Post What do you do after making a design public? Improve it! What do you do when you give your opponents a weapon? Come up with a better one or a way to beat it! What is Wildstang going to do, you ask? Make their drivetrains better! - EricH [more]
Unread 07-05-2010, 23:23
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Re: pic: Prototype Drivetrain
Originally Posted by apalrd View Post
That makes it theoretically worse.
Because the diameter of the circle between the wheels is smaller, it takes less imbalance to cause it to stray to one direction.
You must not have understood what I meant. With this drivetrain design and current wheel placement, it will never be terribly easy to control. With this in mind, I figured it would not make it too much worse to pull the wheels in. We also would be able to use a gyro to help keep it straight (we used one for autonomous this year).
As for the banebots, we used them this year and never had any issues. In the past we have used toughboxes, and they kept breaking. I'm not sure exactly how, but I was told not to use them, and I'm fine with that.
I have no intention of powering the omni's because with this design, there is no good way to get power out to them, short of flipping where the wheels are, which would defeat the purpose of this drive.
Team 241's Turret Prototype ontop of the Harvester Prototype Dantvman27 Robot Showcase 39 08-02-2009 22:53
pic: 499 Prototype drivetrain final layout Andrew Schuetze Extra Discussion 9 01-01-2008 21:37
pic: A drivetrain prototype idea GMAdan Extra Discussion 16 24-04-2007 16:14
1541 Prototype Drivetrain bombadier337 Technical Discussion 12 23-01-2006 08:26
Image Discuss: Team 773 Drivetrain Prototype CD47-Bot Extra Discussion 5 27-01-2003 18:46
