Go to Post Limits are imposed by both man and nature. Understanding those limits and attempting to push past them is the basis of creativity. - Dave.Norton [more]
Unread 07-05-2010, 23:30
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Re: pic: Prototype Drivetrain
Originally Posted by LLogan View Post
I would advise you to drive the four omnis on the corners. Your tractive force is based off of the sum of the forces of friction on all of your wheels. With the design you have right now, you are essentially "wasting" the normal force on the corner wheels. Whatever weight you will have on those sections of the robot will not contribute to your pushing force, giving you less than what you would generally want.
Though the force is "wasted" the majority of the weight will be placed on the drive wheels due to where the CG is. Our current build leader, whom I have discussed this design with, guesstimates that roughly 75% of the weight will be put on the center wheels. Also, I believe that in previous posts I addressed the design goal of maneuverability. The omni's are there as casters, meant to prevent the robot from scratching the floors. There is also the suspension, that will transfer weight during a pushing match onto the center wheel.
Team 241's Turret Prototype ontop of the Harvester Prototype Dantvman27 Robot Showcase 39 08-02-2009 22:53
pic: 499 Prototype drivetrain final layout Andrew Schuetze Extra Discussion 9 01-01-2008 21:37
pic: A drivetrain prototype idea GMAdan Extra Discussion 16 24-04-2007 16:14
1541 Prototype Drivetrain bombadier337 Technical Discussion 12 23-01-2006 08:26
Image Discuss: Team 773 Drivetrain Prototype CD47-Bot Extra Discussion 5 27-01-2003 18:46
