Go to Post I openly admitted to using IE at robotics last year and recieved a major lashing for such blasphemy. Then I downloaded Chrome. - jwallace15 [more]
Unread 08-05-2010, 01:15
LLogan LLogan is offline
Head Screw Tightener/Cheerleader
AKA: Logan
FRC #1261 (Robolions)
LLogan has a spectacular aura aboutLLogan has a spectacular aura about
Re: pic: Prototype Drivetrain
Originally Posted by 548swimmer View Post
Though the force is "wasted" the majority of the weight will be placed on the drive wheels due to where the CG is. Our current build leader, whom I have discussed this design with, guesstimates that roughly 75% of the weight will be put on the center wheels. Also, I believe that in previous posts I addressed the design goal of maneuverability. The omni's are there as casters, meant to prevent the robot from scratching the floors. There is also the suspension, that will transfer weight during a pushing match onto the center wheel.
At the cost of 25% of your tractive force, you gain a theoretical slight advantage in turning. This should raise a very large red-flag. I don't think that losing 25% of your pushing force has ever been a good thing. The turn radius for a dropped center 6WD isn't zero, but it can be pretty close. Driving the omni wheels will not cost you much maneuverability at all. The suspension will not magically "transfer" weight to the center. In fact, a suspension is useful when you want to keep all of your wheels on the ground. A suspension makes sense in a mecanum drive, where you want to make sure that the normal force is distributed as evenly as possible, otherwise the perpendicular vectors don't cancel each other out and you cannot drive straight. The springs in your suspension will actually cause a reactive force and increase the normal force on your omnis, which is the exact opposite of what you want to happen.
I apologize if I'm making the assumption that your omni wheels are on an active suspension. But... I would be even more puzzled if you were to use a floating suspension.
Team 241's Turret Prototype ontop of the Harvester Prototype Dantvman27 Robot Showcase 39 08-02-2009 22:53
pic: 499 Prototype drivetrain final layout Andrew Schuetze Extra Discussion 9 01-01-2008 21:37
pic: A drivetrain prototype idea GMAdan Extra Discussion 16 24-04-2007 16:14
1541 Prototype Drivetrain bombadier337 Technical Discussion 12 23-01-2006 08:26
Image Discuss: Team 773 Drivetrain Prototype CD47-Bot Extra Discussion 5 27-01-2003 18:46
