Go to Post ...I pretty much got the impression that the balls are actually very small, cuddly landmines. - Gui Cavalcanti [more]
Unread 08-05-2010, 10:39
gyaniv's Avatar
gyaniv gyaniv is offline
AKA: Gutman Yaniv
FRC #2230 (General Angels)
gyaniv has a spectacular aura aboutgyaniv has a spectacular aura about
Re: pic: Prototype Drivetrain
OK... This is really starting to annoy me...
Seriously, if you want a zero turn radius robot, you don't need to put 2 wheels in the mid and hope this will work...
you just need that all the wheels will get the same amount of torque and speed, and that all of them will be in the same distance from the center of the turning radius ( Even if it is zero turning radius there is still a center-point) . This will apply for 4WD.
For 6WD you need that the 4 outer wheels will be just like the 4WD logic i said above and that the 2 center wheels will be exactly in the center between the two other wheels at each side.
Another thing, when you design a drive-train take to consideration the specific game, for most teams this drive-train will be a disaster for LUNACY and BREAKAWAY since in those games the space in the center of the robot was important for the mission. you want that your drive-train will take the least space as it can on the robot, and weigh as low as possible so all the other resources can go to the other robot mechanisms. But don't forget that the drive system should be as much maneuverability as you need to the certain game, easy to control for the driver, and that will almost need none program correction as possible (unless you MUST).
FRC Team 2230 - Student - 2009-2011
FRC Team 2230 & 4406 - Mentor - 2012
FRC Team 2230 - Mentor - 2013-present
"A mentor's job is to understand what the students are trying to make, and bend the laws of physics to make that happen"
Team 241's Turret Prototype ontop of the Harvester Prototype Dantvman27 Robot Showcase 39 08-02-2009 22:53
pic: 499 Prototype drivetrain final layout Andrew Schuetze Extra Discussion 9 01-01-2008 21:37
pic: A drivetrain prototype idea GMAdan Extra Discussion 16 24-04-2007 16:14
1541 Prototype Drivetrain bombadier337 Technical Discussion 12 23-01-2006 08:26
Image Discuss: Team 773 Drivetrain Prototype CD47-Bot Extra Discussion 5 27-01-2003 18:46
