Go to Post Facebook for FIRST already exists. It's called Facebook :) - dcarr [more]
Unread 09-05-2010, 02:00
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Re: pic: Prototype Drivetrain v2
Originally Posted by EugeneF View Post
The point of using omnis is to avoid needing to "rock." I don't get how it would be smoother to have it rock AND have omnis.
And if you want it to rock, why don't you just drop the center and forget about the suspension?
If you want to still have the suspension, you could either do what you suggested or make the suspension go up and down along an arc with radius equal to the distance between the front and middle wheels, so the chain has a constant distance.
How can I make the carriages pivot around the center axel?
There is currently no rock at rest. Once you begin moving the suspension absorbs any jarring movements like sudden stops or turns, making it handle more smoothly.
pic: Prototype Drivetrain 548swimmer Extra Discussion 38 09-05-2010 21:14
pic: 499 Prototype drivetrain final layout Andrew Schuetze Extra Discussion 9 01-01-2008 21:37
pic: A drivetrain prototype idea GMAdan Extra Discussion 16 24-04-2007 16:14
1541 Prototype Drivetrain bombadier337 Technical Discussion 12 23-01-2006 08:26
Image Discuss: Team 773 Drivetrain Prototype CD47-Bot Extra Discussion 5 27-01-2003 18:46
