Go to Post I like how we're trying to save weight when we came in at 95 pounds. - Chris is me [more]
Unread 12-05-2010, 20:51
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Re: pic: 4in Wheel CAD
Why do you shy away from delrin? This year, we found it easy to machine. We made our wheels out of it this year. As for the threaded inserts, how would you recommend attaching the side plates instead? I was looking for a way to avoid bolting all the way through, adding much unnecessary weight. This year we used standoffs, but that was expensive. Aluminum bolts would make it even lighter, if we could find a good option. I do like the idea of making the sprocket have more of a structural use.
Here is a picture without the sprocket attached:
Peter, could you elaborate on how this press fit worked? It sounds like a great idea and a way to avoid welding with aluminum. The tube you mentioned, did you just buy an aluminum tube from mcmaster? How were the tolerances? How did you keep the inside part from slipping?
2009 Palmetto Regional Champs
pic: New wheel CAD CraigHickman Extra Discussion 9 02-01-2008 20:29
pic: New wheel CAD CraigHickman Extra Discussion 4 08-09-2007 01:29
Mecanum Wheel CAD file or Drawing Leav Technical Discussion 2 17-01-2006 06:35
pic: Team 759 CAD pic (almost finished) oljomo Extra Discussion 6 01-03-2005 16:31
