Go to Post Either you have it hooked up wrong, or you have the Battery of the Gods. Probably filled with Mountain Dew... - nighterfighter [more]
Unread 13-05-2010, 02:18
M. Mellott's Avatar
CAD God
AKA: Mike Mellott
Re: pic: 4in Wheel CAD
Are there spacers between the sprockets and outer plates? I can't tell and didn't want to assume. You'll definitely need these if they're not already there.
While the design looks great, it's going to be difficult to get those sharp corners in the plate. Are these being cut out with a water jet? If not, you may need to add blends to the design for your cutter.
Also, since total price is a design factor, with a 4" dia. x 1" thick disc of Delrin costing between $15-$20, are you really saving money?
pic: New wheel CAD CraigHickman Extra Discussion 9 02-01-2008 20:29
pic: New wheel CAD CraigHickman Extra Discussion 4 08-09-2007 01:29
Mecanum Wheel CAD file or Drawing Leav Technical Discussion 2 17-01-2006 06:35
pic: Team 759 CAD pic (almost finished) oljomo Extra Discussion 6 01-03-2005 16:31
