Go to Post That's awesome. I sort of like the smaller venues. You get to know teams on a lot more personal level. - thisOrrthat [more]
Unread 16-05-2010, 21:21
IanW's Avatar
IanW IanW is offline
Rookie Mentor
AKA: Ian
FRC #0997 (Spartans)
pic: 6 Wheel Drive Render 2.0
Unread 16-05-2010, 21:23
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Re: pic: 6 Wheel Drive Render 2.0
if there are omni wheels on the sides, why does the center wheel have to be dropped that much, i would go with 1/6 because the omni wheels will wear about the same.
Unread 16-05-2010, 21:40
this one looks much better than your first... i am making a few chassis which i will upload later... who knows, i might see some of these chassis out on the field for next year
Unread 16-05-2010, 21:43
1/8 is less than 1/6.
Wheel drops generally aren't picked because of tread wear.
Unread 17-05-2010, 00:05
Edoc'sil's Avatar
Edoc'sil Edoc'sil is offline
FRC #2531
Edoc'sil has a spectacular aura aboutEdoc'sil has a spectacular aura about
If those are andymark wheels you actually have to drop the plaction wheel down 1/8 ish, because even though supposedly the wheels have the same diameter, they really do not.
Sucks if your plactions are not touching the ground.
Here lies a toppled god-
His fall was not a small one.
We did but build his pedestal,
A narrow and a tall one.
Unread 17-05-2010, 17:49
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Are the omnis necessary on this chassis? We have just about the same design with a very small drop in the middle with no omnis at all and it has to be one of the most smooth-driving chassis we have ever had!
Im just wondering.
Unread 17-05-2010, 18:52
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
I would change from four omni wheels to two omni wheels on the opposite corners with standard drive wheels in the other corners. With just two omni wheels in the oposit corners you will have btter traction and you will be able to turn easy. Or if you are droping the center wheels forget the omnis all together.
Unread 18-05-2010, 10:21
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Won't the traction wheels in the opposite corners cause too much friction to turn assuming all wheels are on the same plane? The point of a rocker is to cause a wheel configuration that is shorter than it is wide. With omni's in opposite corners, you will not have this configuration. This could potentially prevent turning. Prototype it though.
pic: 4 inch Wheel Render Chris is me Extra Discussion 25 15-05-2010 18:43
pic: 6 Wheel Drive Render IanW Extra Discussion 6 08-05-2010 11:39
