Go to Post Each poster can bring respect to the topic, whether agreeing with it or not. - JaneYoung [more]
Unread 17-05-2010, 15:05
pathew100 pathew100 is offline
AKA: Pat Murphy
FRC #0862 (Lightning Robtics)
pathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud of
Send a message via AIM to pathew100
Re: paper: MARC 2010 Rule Changes
It's not a secret either. There is an amber light on the scoring control box above the middle driver's station. Normally the light is OFF.
The light turns ON for 10 seconds at the end of a match (when the buzzer sounds). When the light turns OFF then the scoring controller stops counting.
Also, the light will blink/flash during a match when DOGMA has assessed a penalty for that side (Red or Blue).
Some teams knew about it, some didn't, which is maybe an unfair advantage. If you can see that the other side got a DOGMA (which is not counted in "real time" total on the audience screen, btw) then it might make a difference in your strategy...
MARC 2010 IS OPEN Steve Ketron General Forum 142 30-06-2010 00:59
MARC 2010 Update #3 Steve Ketron General Forum 12 24-06-2010 13:44
Rule change suggestions for MARC 2010 GaryVoshol General Forum 50 17-05-2010 07:28
paper: 2007 MARC Volunteer Needs Overview KTorak Extra Discussion 3 03-05-2007 06:54
Rule Changes? archiver 1999 6 23-06-2002 22:15
