Go to Post To me, being in FIRST is the biggest learning experience anyone can have. I want to give that experience to everyone I can, be it now or thirty years down the line. - BandChick [more]
Unread 18-05-2010, 09:55
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Re: pic: Drivetrain Prototype
I'm not particularly qualified to talk about drive chassis durability, so I don't have much to add.
However, I think I can save you some weight on this, or another drive train that you build. Having a pair of sprockets with built in hubs is heavy, and having those extra couple of inches of steel shaft is heavier. What you could do is take an AM hub and attach a pair of sprockets to it, spacing the sprockets with bits of plastic. Then just run enough shaft to cantilever the sprockets and hub.
A top down view would look like = []: () : ()
Where = is shaft, : are spacers, () are sprockets, and [] is the hub. Spaces are only there to prevent them from being turned into smilies.
Does that make sense?
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
pic: prototype drivetrain v2.1 548swimmer Extra Discussion 16 11-05-2010 09:05
pic: Prototype Drivetrain v2 548swimmer Extra Discussion 47 11-05-2010 01:13
pic: Prototype Drivetrain 548swimmer Extra Discussion 38 09-05-2010 21:14
pic: 499 Prototype drivetrain final layout Andrew Schuetze Extra Discussion 9 01-01-2008 21:37
pic: A drivetrain prototype idea GMAdan Extra Discussion 16 24-04-2007 16:14
