Go to Post And then since this is GTR-W there's also maple syrup somewhere and the drive team says "Sooory." - PayneTrain [more]
Unread 18-05-2010, 18:00
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: pic: A mechanum wheel that shouldn't bump around at all.
Originally Posted by exprg:melonhead View Post
hmmm... this wheel sure does look pretty, but does it run that way too? the side wheels (or whatever the technical term for them may be) look as if they are at a very harsh angle. now, i'm just a programmer, but isn't the ideal angle 45 degrees?
There is no "ideal" angle.
Many mecanum wheels have rollers at 45 degrees. This makes the kinematic (and dynamic) analysis easier. The forward and inverse kinematic matrix transformations are simple, with no trig functions or square roots.
Making the angle smaller than 45 degrees (angle between roller axis and plane of the wheel) improves forward/reverse traction but reduces strafing traction, and vice versa.
So there is no one ideal angle. It depends on the application.
pic: Alternate view of Mechanum wheel, with blue rollers added. Hawiian Cadder Extra Discussion 5 15-05-2010 02:23
Mechanum Wheel Rollers Stuck ienjoymycereal Technical Discussion 5 31-01-2010 22:38
pic: 342 8-wheel articulation on bump hipsterjr Extra Discussion 5 31-01-2010 11:26
pic: 662 gets a tube wrapped around the wheel gburlison Extra Discussion 10 02-04-2007 17:39
pic: SpamThingAcon Mechanum wheel system Tytus Gerrish Extra Discussion 18 12-05-2005 04:40
