Go to Post Wait, does this mean TV isn't real? I'm shocked and appalled. - s_forbes [more]
Unread 19-05-2010, 08:39
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Re: pic: team 159 mechanum wheel, itteration 2
each roller has an axle which is .5 inches in diameter, however the last 3/16 of that axle will be turned down to 1/8 inches in diameter. on the fat edge of the roller a 1.125 od .5 id bearing will press fit in, on the outside a .75 od, .125 id bearing will fit in. as part of the new design, the rollers will not be printed, however we will print a mold, for urethane casting. our printer has a resolution of about 1/64 of an inch, so the rollers will have the texture of 60 grit sandpaper in theory. i may add a little more texture too before printing. the last thing to add is rubber weather coating. it is sort of spray on rubber, designed for protecting patio furniture. it is incredibly tough, and creates a very thing coating which should give the rollers a tiny bit of tread.
as always, any comments are appreciated, these might be built the coming season, but definitely will be built the following season.
pic: A mechanum wheel that shouldn't bump around at all. Hawiian Cadder Extra Discussion 47 20-05-2010 23:31
pic: Alternate view of Mechanum wheel, with blue rollers added. Hawiian Cadder Extra Discussion 5 15-05-2010 02:23
Mechanum Wheel Rollers Stuck ienjoymycereal Technical Discussion 5 31-01-2010 22:38
pic: Drinks Consumed by Team 159 Damian Manda Extra Discussion 10 27-03-2006 15:34
pic: SpamThingAcon Mechanum wheel system Tytus Gerrish Extra Discussion 18 12-05-2005 04:40
