Go to Post Why does school have to get in the way of more important things like FIRST? When would we ever need to know about the stuff there teaching in here? - Briansmithtown [more]
Unread 19-05-2010, 10:14
exprg:melonhead's Avatar
exprg:melonhead exprg:melonhead is offline
The Teamless/ Travelling Mentor
AKA: Justin Sticht
FRC #3278 (Qwerty)
exprg:melonhead has a spectacular aura aboutexprg:melonhead has a spectacular aura aboutexprg:melonhead has a spectacular aura about
Re: pic: A mechanum wheel that shouldn't bump around at all.
There is no "ideal" angle.
Many mecanum wheels have rollers at 45 degrees. This makes the kinematic (and dynamic) analysis easier. The forward and inverse kinematic matrix transformations are simple, with no trig functions or square roots.
Making the angle smaller than 45 degrees (angle between roller axis and plane of the wheel) improves forward/reverse traction but reduces strafing traction, and vice versa.
So there is no one ideal angle. It depends on the application.
so what you are saying is that in order to to drive easily both forward and back, it would be best to have a good 45 degree?
pic: Alternate view of Mechanum wheel, with blue rollers added. Hawiian Cadder Extra Discussion 5 15-05-2010 02:23
Mechanum Wheel Rollers Stuck ienjoymycereal Technical Discussion 5 31-01-2010 22:38
pic: 342 8-wheel articulation on bump hipsterjr Extra Discussion 5 31-01-2010 11:26
pic: 662 gets a tube wrapped around the wheel gburlison Extra Discussion 10 02-04-2007 17:39
pic: SpamThingAcon Mechanum wheel system Tytus Gerrish Extra Discussion 18 12-05-2005 04:40
