Go to Post You definitely know you've overdosed on first when you wash the aluminum shavings off your hands AFTER you eat dinner. - Maxpower57 [more]
Unread 19-05-2010, 11:06
Rion Atkinson's Avatar
The CAD Guy
Re: pic: Drivetrain Prototype
Originally Posted by Andrew Schreiber View Post
Op, my only suggestion to you is to use the Toughboxes in the KOP. Not knocking the P80s at all but why spend money when you don't have to? Also, a word of caution, a wide stance bot like this will be susceptible to tipping if your CG is too high. In a game where you have to have a large arm lifting a heavy object (2008, 2005) I would be cautious about using a wide stance bot like this without outriggers (see 118 in 2005 or 33 in 2008 for a good example).
On the "wide stance tipping" comment I'll back that up, all the way up until the point where the arm is required to reach right to left of the robot. Then wide stance would probably be the better option. (In my opinion)
I'll echo what Akash said. If you aren't going to flange the metal, don't put holes in it. You need that strength. (If you don't know what flanges are, I'll be more than happy to explain.
Also, your bars going all the way across. You really only need them to be 1/8" wall. I would put three on top, two one bottom. Or even two on two, and two on bottom. I would also only take them across the center of the chassis and then use stand-offs to support the outer cover, done right you will be plenty strong enough.
My $0.02
-Rion
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
pic: prototype drivetrain v2.1 548swimmer Extra Discussion 16 11-05-2010 09:05
pic: Prototype Drivetrain v2 548swimmer Extra Discussion 47 11-05-2010 01:13
pic: Prototype Drivetrain 548swimmer Extra Discussion 38 09-05-2010 21:14
pic: 499 Prototype drivetrain final layout Andrew Schuetze Extra Discussion 9 01-01-2008 21:37
pic: A drivetrain prototype idea GMAdan Extra Discussion 16 24-04-2007 16:14
