Go to Post Come on baby, do the logomotion with me. - JaneYoung [more]
Unread 19-05-2010, 19:50
EricH EricH is offline
Re: pic: A mechanum wheel that shouldn't bump around at all.
No, that's not what I said (not even close). I'm not sure how you concluded that from what I wrote. Help me understand what part led you astray.
I can understand why he said that... But to ONLY go forwards and backwards, it's best to have a traction wheel. (literally, he said forwards and backwards only...)
What Ether said, in essence, was that many mecanum wheels used 45* rollers, but that other angles could be used--less than 45* puts the advantage to front/back and greater than 45* puts the advantage side-side in terms of traction. I assume that this is a correct summary. If it is not, then the original post needs to be modified, as that is where I got this from.
From that, it is easily (and logically) concluded that, for the optimal front/back and side/side traction, 45* is a better angle than many others. If that is not the conclusion that was intended, then better words need to be chosen.
pic: Alternate view of Mechanum wheel, with blue rollers added. Hawiian Cadder Extra Discussion 5 15-05-2010 02:23
Mechanum Wheel Rollers Stuck ienjoymycereal Technical Discussion 5 31-01-2010 22:38
pic: 342 8-wheel articulation on bump hipsterjr Extra Discussion 5 31-01-2010 11:26
pic: 662 gets a tube wrapped around the wheel gburlison Extra Discussion 10 02-04-2007 17:39
pic: SpamThingAcon Mechanum wheel system Tytus Gerrish Extra Discussion 18 12-05-2005 04:40
