Re: pic: WCD Chassis Idea
With modeling with CIM vs. FP. It actually doesn't matter. I had those things with one CIM in it. Turns out the FP is only like a 1/4 inch shorter. So it doesn't really matter. Quote:
As for the cross bars, I do believe you are right. I'll probably have some sheet metal fun and make the belly pan those cross bars as well. Quote:
I have a feeling that the biggest problems with bending would be on the outside edges rather than in the middle. Which as you said is easily fixed with more cross braces. Or as I said earlier. I belly pan. ![]() |
The volume of space taken up by a FP is significantly smaller than that of a CIM. This year at West Michigan we replaced a FP with a CIM and had to move around our compressor because two objects seem to have an aversion to occupying the same point in space. Long story short, model with the largest thing you might ever put in there and then be pleasantly surprised when you have extra space.
Last edited by Andrew Schreiber : 20-05-2010 at 13:58. Reason: Wow, I must have been half asleep, FP larger than CIM? |
usually how many CIM or FP motors are allowed during the FIRST competitions? I heard during the build for Breakaway that we could only use 5 CIM motors. So there would be a shortage of one motor for that system. plus, that uses up all of your allowed CIM motors. so there would be a bit of a sacrifice using those transmissions if your team needed a strong motor for another mechanism.
Can anyone tell me the typical limit on Fisher Price motors? (Or is there not one?) |
I always try and model stuff with CIMs anywhere I want to put FP+AMs. That way no matter what iterations you do involving switching motor position you know the biggest possible motor will fit everywhere.
I just meant it was a bit of stretch simply because we've been allowed to use roughly 2 FPs, but if this an off-season project, then do what you wish.
It is good engineering practice to know your resource limitations before you start to design something. RTFM please.
Also, if you would love to quiz me on this years game. Go for it, and be shocked. I am the only one that read the manual this year, so I know this stuff. I just have a tendency to forget this after 3 months. Know some background info before making assumptions. Last edited by Rion Atkinson : 20-05-2010 at 23:15. |
How many FP motors were allowed? "We know what we have, and what we can do. Lets start with that." Brushing up on the rules generally helps the design along. Last edited by Mike Schreiber : 20-05-2010 at 23:43. |
#10
Okay you have a good point. But the way you came a cross seemed high and mighty; which I tend to have issues with. I agree. I could have gone looking. But sense we were on the topic, it was quicker just to ask the question sense i have other things to be doing as well. And seeing as I don't even have a team right now, or the means to make this. I don't expect the design to even come to life, so I wasn't exactly worried about the rules of how many.
#11
Or make them up. Adding constraints to your designs will cause you to think of interesting solutions. Say for example you don't want to use wheels to move, cad a solution to that. Or the ever popular Jello game, figure out how to move on Jello. Yeah letting your imagination go wild is great but without constraints your work is worthless as both a practical design and as an effective mental exercise.
Some suggested constraints: Sub 30lb drive train (INCLUDING electronics) Modular drive train Drive train that can accept multiple types of wheels and still remain functional (Think mecanum or 6" plactions) Get away from the all aluminum designs. Robot that can traverse a 6" step (using 4" wheels). Robots that could move up a wall. Basically let's try to get away from the design mantra of Copy 254 that I keep seeing. "Oh, I know, let's all make pretty renders of basically the same darn thing" Show some creativity, show some uniqueness. You know the nonadrive was designed by a student over the summer right? That is new and I would LOVE to see something like that. Even if it has no practical use right now. |
#13
If you clamp everything tightly,fixturing your angles correctly you can use welding rod to fill the gaps, that will probably be between the parts, and keep everything true. It is just not as easy and straightforward as most teams seem to go for. It is possible just not easy and you have to spend the time fixturing and planning before you weld so that the finished product comes out correct. |
#14
this year and in years past we have been limited to 2 FP motors.
#15
Instead of adding more crossmembers, you would be better off using the plans of a traditional WCD and add on a belly pan. Another version which I personally love is 418's, designed by roboticwanderer (Lewis). The combination of 2x1 and 1x1 allows for clean chain runs too.
http://www.chiefdelphi.com/media/photos/31575 . |
| pic: WCD Sheet Metal Concept Chassis | GarrettF2395 | Extra Discussion | 22 | 20-05-2010 16:33 |
| pic: Chassis Idea | Rion Atkinson | Extra Discussion | 38 | 02-01-2010 04:56 |
| pic: Chassis Idea | Rion Atkinson | Extra Discussion | 17 | 25-08-2009 13:24 |
| New AM C-Base Chassis vs. Old IFI KitBot Chassis? | ChuckDickerson | Kit & Additional Hardware | 5 | 06-01-2009 08:36 |
