Go to Post In FIRST you have the right to remain silent, anything you say can and will be held against you and your associates in the court of public opinion. - Koko Ed [more]
Unread 17-05-2010, 21:01
artdutra04's Avatar
VEX Robotics Engineer
Re: pic: WCD Sheet Metal Concept Chassis
Originally Posted by JamesCH95 View Post
Certainly a valid option, but if you get one over-zealous person (think finals match 5-minute repairs) who spins or strips a pressed-in nut you could find yourself totally hosed. If the nut is riveted in then the rivets can be drilled out and a new nut riveted in very quickly. I work with an ex-A&P mechanic and we've used these nuts with great success.
#8-32 and #10-32 PEM nuts both use a .25 or smaller hole that they are pressed into. If there is ever an issue where they get stripped/pushed out, they can be replaced with a 1/4-20 bolt and nut. We've been using them for two years now on critical drive train/chassis sheet metal components, and as far as I know have yet to have one strip or fail.
Originally Posted by Formerly Famous View Post
Care to explain the DarkSoul chain breaker? And how it eliminates the need of the master link? I looked around and couldn't find anything but the words "out of stock" and "this item no longer available".
Instead of using a master link, the DarkSoul chain break is used is used to drive the pins [partially] out of the roller chain, put two ends of the chain together, and then drive the pin back in. There is no master link because any link can be the 'master link'.
It's too bad about the out of stock issues; the one we picked up back in December has proven to be one of our most useful tools. If the DarkSoul chain breaks are no longer in production, it's not a very difficult device to reverse engineer and machine yourself on a milling machine.
Art Dutra IV
世上无难事,只怕有心人.
Unread 19-05-2010, 17:50
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
http://www.aircraftspruce.com/menus/ha/nut_anchor.html
I realize Aircraft Spruce isn't the cheapest place to buy things, but it's the first source that came to mind.
Ack! Don't buy things from Aircraft Spruce, they have awful customer service, and habit of messing up orders. A good friend responsible for maintenance on 30 antique airplanes has had them screw up more than one large (>1k) order. On the other hand, he's never had a problem with Wicks.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 20-05-2010, 09:03
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
I've never had a problem with Aircraft Spruce, nor has my co-worker who is an ex-A&P mechanic. =shrug=
Unread 20-05-2010, 10:58
Rion Atkinson's Avatar
The CAD Guy
I'm not entirely certain. But I have a feeling businesses don't care what peoples jobs are when their orders get messed up.
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
Unread 20-05-2010, 11:38
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
An A&P mechanic (Airframe and Powerplant) is an aircraft mechanic, I was merely implying that he ordered from Aircraft Spruce frequently.
Unread 20-05-2010, 13:01
The CAD Guy
Okay. I see what you were getting at now. haha. Sorry bout that.
Start Something
Unread 20-05-2010, 13:41
ajlapp ajlapp is offline
AKA: Anthony Lapp
Its a shame that we can't get more of these breakers........We are currently working on a replacement. I'll keep the forum updated when we have them back in stock.
Anthony Lapp
FIRST Engineering Mentor
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Unread 20-05-2010, 16:33
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
I've used a regular chain breaker to push the pins back through, then taken a hammer and peened the pins back over using a bench vise as an anvil. It is low-tech and requires a little practice to keep from binding up the chain, but it works.
pic: Sheet Metal Drivetrain Jacob Paikoff Extra Discussion 14 30-04-2010 11:21
pic: GUS Team 228's 6WD Sheet Metal Prototype Chassis artdutra04 Extra Discussion 14 02-01-2009 02:11
pic: New Chassis Concept chris31 Extra Discussion 35 11-12-2008 11:43
pic: 8WD 'Suspension' Chassis Concept JesseK Extra Discussion 8 09-12-2008 22:00
[OCCRA]: Bending Sheet Metal troy_573 OCCRA Q&A 1 19-09-2005 22:27
