Re: pic: WCD Chassis Idea
If you clamp everything tightly,fixturing your angles correctly you can use welding rod to fill the gaps, that will probably be between the parts, and keep everything true. It is just not as easy and straightforward as most teams seem to go for. It is possible just not easy and you have to spend the time fixturing and planning before you weld so that the finished product comes out correct. |
this year and in years past we have been limited to 2 FP motors.
Instead of adding more crossmembers, you would be better off using the plans of a traditional WCD and add on a belly pan. Another version which I personally love is 418's, designed by roboticwanderer (Lewis). The combination of 2x1 and 1x1 allows for clean chain runs too.
http://www.chiefdelphi.com/media/photos/31575 . |
2 FP's (or however many are in the KOP--typically 2, since at least 2004), 2 CIMs from the KOP, up to X (typically 2, but 3 in 2010) extra CIMs allowed.
To do this, you'd need 4 CIMs and 2 FPs, leaving 1 CIM, the window motors, the RS-55Xs, and pneumatics to do anything else you wanted to do. |
Looks awesome, Rion! Thanks for sharing with us.
I know you said the gearbox is still in development, but is it going to be a two-speed? I'm excited to see the final version! Keep up the great work! |
It will indeed be a two speed gearbox. I'm taking the second stage out today, but yeah, two speed. |
| pic: WCD Sheet Metal Concept Chassis | GarrettF2395 | Extra Discussion | 22 | 20-05-2010 16:33 |
| pic: Chassis Idea | Rion Atkinson | Extra Discussion | 38 | 02-01-2010 04:56 |
| pic: Chassis Idea | Rion Atkinson | Extra Discussion | 17 | 25-08-2009 13:24 |
| New AM C-Base Chassis vs. Old IFI KitBot Chassis? | ChuckDickerson | Kit & Additional Hardware | 5 | 06-01-2009 08:36 |
