Go to Post A robot with hands would be cool! - Koko Ed [more]
  #43   Spotlight this post!
Unread 20-05-2010, 23:22
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: pic: A mechanum wheel that shouldn't bump around at all.
Originally Posted by exprg:melonhead View Post
ok. here's what confuses me. if i want a robot that drives just as easily sideways as it does front and back, would it be best to have a 45.
Yes, that's probably a pretty good rule of thumb. You're on the right track. The important thing is to try to make the roller bearing friction as low as possible. For "zero" roller bearing friction, 45 degrees will make fore/aft and sideways motions equally easy. But since there is always some roller bearing friction, you might need to increase the roller angle slightly (make the roller axis closer to the wheel axis) if you want to make both motions equally easy.
the way i see it, the more you get away from that angle, the more energy it will take to move it sideways. correct me if i'm wrong because i feel like i'm missing a huge part of the puzzle here.
You've got the right idea Justin. The more you get away from 45 degrees in one direction (i.e. smaller angle - roller axis becoming parallel to the plane of the wheel), the less efficient the sideways motion becomes. Moving the roller axis the other direction makes sideways motion more efficient - up to a point, depending on the roller bearing friction.
Take a careful look at posts 39, 41, 43, 44, and 45 in this thread - there's lots of good detailed explanation there. Ask questions about anything that's unclear.
pic: Alternate view of Mechanum wheel, with blue rollers added. Hawiian Cadder Extra Discussion 5 15-05-2010 02:23
Mechanum Wheel Rollers Stuck ienjoymycereal Technical Discussion 5 31-01-2010 22:38
pic: 342 8-wheel articulation on bump hipsterjr Extra Discussion 5 31-01-2010 11:26
pic: 662 gets a tube wrapped around the wheel gburlison Extra Discussion 10 02-04-2007 17:39
pic: SpamThingAcon Mechanum wheel system Tytus Gerrish Extra Discussion 18 12-05-2005 04:40
