Go to Post What's the reason for having a rule if it's not enforced? - jpsaul7usa [more]
  #44   Spotlight this post!
Unread 20-05-2010, 23:31
exprg:melonhead's Avatar
exprg:melonhead exprg:melonhead is offline
The Teamless/ Travelling Mentor
AKA: Justin Sticht
FRC #3278 (Qwerty)
exprg:melonhead has a spectacular aura aboutexprg:melonhead has a spectacular aura aboutexprg:melonhead has a spectacular aura about
Re: pic: A mechanum wheel that shouldn't bump around at all.
You've got the right idea Justin. The more you get away from 45 degrees in one direction (i.e. smaller angle - roller axis becoming parallel to the plane of the wheel), the less efficient the sideways motion becomes.
thank you so much for helping explain this. i know it's hard to explain this through writing, and i know i don't usually learn well this way. you helped so much on clearing this up for me. i appreciate it.
pic: Alternate view of Mechanum wheel, with blue rollers added. Hawiian Cadder Extra Discussion 5 15-05-2010 02:23
Mechanum Wheel Rollers Stuck ienjoymycereal Technical Discussion 5 31-01-2010 22:38
pic: 342 8-wheel articulation on bump hipsterjr Extra Discussion 5 31-01-2010 11:26
pic: 662 gets a tube wrapped around the wheel gburlison Extra Discussion 10 02-04-2007 17:39
pic: SpamThingAcon Mechanum wheel system Tytus Gerrish Extra Discussion 18 12-05-2005 04:40
