Go to Post These are words on a computer screen, please stop giving the text on this screen such incredible power over how you feel. - Stephen Kowski [more]
Unread 21-05-2010, 14:22
Edoc'sil's Avatar
Edoc'sil Edoc'sil is offline
FRC #2531
Edoc'sil has a spectacular aura aboutEdoc'sil has a spectacular aura about
Re: pic: 6 wheel drive, built in tensioner and shifting.
Oops, I thought this image failed to post, so I started a thread here. http://www.chiefdelphi.com/forums/sh...threadid=85872 hopefully we can concentrate the discussion there as I have several other views posted.
however i will respond to the previous post here for clarity. It is 1/2 aluminum, backed with 30x30 flexmation, it is strong enough, I have experience with this style of fabrication. Basically the flexmation take most of the stress side to side and the aluminum is quite thick vertically at all of the critical, weight bearing points (ie. at the wheels) of the aluminum plate itself.
Here lies a toppled god-
His fall was not a small one.
We did but build his pedestal,
A narrow and a tall one.
6 wheel drive with chain tensioners and shifting Edoc'sil Technical Discussion 20 24-05-2010 20:46
pic: Built third try drive. joeweber Extra Discussion 6 14-12-2009 18:55
pic: 885 Right-center wheel and drive assembly CD47-Bot Robot Showcase 2 30-04-2004 18:27
