Go to Post it's not because the kids look up to him that [Dave] gets picked on, it's really because it's just so much fun. - MissInformation [more]
Unread 26-05-2010, 00:34
CraigHickman
Re: pic: 3 Motor Single Speed Gearbox
Originally Posted by sanddrag View Post
I would not recommend Delrin plates. Holding tolerance is more difficult, and they flex, causing gear wear issues.
We did a gearbox with delrin plates, and the gears wore about twice as quickly as our aluminum boxes.
Also, assembling the box with the motor bolts is quite doable, but makes assembling a bit of a hand gymnastics exercise.
Edit: A bit of a suggestion: If you can recess the standoffs to allow the box to 'snap' together, it makes assembly much easier, and makes aligning parts much quicker.
pic: Simple single reduction duel CIM gearbox Lowfategg Extra Discussion 11 05-10-2009 22:47
White Paper Discuss: Team 179 conceptual - single speed - 3 motor gearbox CD47-Bot Extra Discussion 9 30-08-2004 21:57
Multi Speed Dual Motor Gearbox tenfour General Forum 14 08-09-2003 13:09
