26-05-2010, 01:49
Re: pic: 3 Motor Single Speed Gearbox
Originally Posted by AdamHeard
One advantage of 1/4" plate here is it lets you put the CIMs real close to each other without the bearing popping through and hitting them.
That's pretty much the only reason, and I wanted two identical plates. You can't put 3 CIMs on the gearbox with this ratio without overlapping the bearings.
