Go to Post Step 1: Get Drill Step 2: Insert 1/2"-1" bit into drill Step 3: Drill Those Speed Holes! - Adam Richards [more]
Unread 26-05-2010, 07:14
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Re: pic: 3 Motor Single Speed Gearbox
That's pretty much the only reason, and I wanted two identical plates. You can't put 3 CIMs on the gearbox with this ratio without overlapping the bearings.
The Team221 WildSwerve modules use a 1/8" bearing shim so that 1/8" plates can be used. They work pretty well. I'll see if i can find a picture.
Also, I wouldn't use the motor mounting holes as the gearbox plate holes, mainly because I like those motor mounts TIGHT and sometimes gearbox assembly bolts need to be loosened a little bit so the gearbox can run with less internal friction. I suppose that may be a personal bias though and not a requirement.
One other thing to think about: How would this mount onto the frame of a robot? The machined plates look cool, but how would you mount it? That's probably too much of a robot-specific question to fully answer right now but is worth thinking about.
Looks good. Keep up the hard work.
Collin Fultz
pic: Simple single reduction duel CIM gearbox Lowfategg Extra Discussion 11 05-10-2009 22:47
White Paper Discuss: Team 179 conceptual - single speed - 3 motor gearbox CD47-Bot Extra Discussion 9 30-08-2004 21:57
Multi Speed Dual Motor Gearbox tenfour General Forum 14 08-09-2003 13:09
