Go to Post Consider how nature does this, and emulate. Nature usually has a pretty good algorithm. - DonRotolo [more]
Unread 28-05-2010, 00:23
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: pic: aces high drive base concept
I like it for a simple drivetrain. A couple things to think of. How are you actually going to tension the chain? I see guides but nothing adjustable. Also it might be easier to drop the transmission down between 2 of the wheels and just have 3 separate chain runs. It would lower the Center of gravity as well as increase redundancy a bit. This design doesnt look like you're really using the 80-20 adjustability so why not just use plain aluminum tube? You would save weight and potential failure points from loosening fasteners if you weld it
Mentor 2415
pic: Aces High 176 Breakaway Bot AcesJames Extra Discussion 10 07-03-2010 22:05
Aces High on Ice BobC General Forum 9 04-02-2008 09:36
pic: Aces High 176 testing drive BobC Extra Discussion 6 27-01-2007 19:39
Aces High Raffle BobC General Forum 20 08-12-2006 08:09
pic: This is Pokerface from ACES HIGH 176 desi_technology Extra Discussion 1 21-03-2006 15:47
