28-05-2010, 00:41
Re: pic: aces high drive base concept
Originally Posted by sdcantrell56
I like it for a simple drivetrain. A couple things to think of. How are you actually going to tension the chain? I see guides but nothing adjustable. Also it might be easier to drop the transmission down between 2 of the wheels and just have 3 separate chain runs. It would lower the Center of gravity as well as increase redundancy a bit. This design doesnt look like you're really using the 80-20 adjustability so why not just use plain aluminum tube? You would save weight and potential failure points from loosening fasteners if you weld it
If you weld or drill through 80/20 in this fashion you get pretty much the same weight as 1/8 wall tube and adjustability for whatever you put on top of it. Worked for Shaker this year.
It might be easier to run a Supershifter in the middle.
