Go to Post Is it bad when are you just sitting at home wishing KICKOFF was here. - JulieB [more]
Unread 23-06-2010, 09:21
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
Re: pic: VEX Solar Tracker Gearbox
For a solar tracker running at such a slow output speed, you could probably size the gearbox based on the load (whatever you are mounting that looks at the sun, a PV array?), not the speed. You can pulse the motor at time intervals to decrease the effective input speed (turn it on for a few seconds every 10 -15 seconds) and it will be more than adequate. 360 degrees per day is 0.07 mrad per second. The sun is 9.5 mrad in diameter, so it takes over 2 minutes to move across a focused point along the centerline. Commercial heliostat trackers send position commands every 10 seconds, and they require much higher accuracy than a CPV tracker.
Close enough to taste it, too far to reach it
pic: VEX High Reduction Gearbox JVN Extra Discussion 40 06-07-2009 16:58
pic: Vex 2-speed gearbox crazykid234 Extra Discussion 3 03-01-2006 20:18
Solar Power? dddriveman Electrical 26 26-06-2003 18:44
