Go to Post FIRST gives everyone lots of practice in getting used to late nights. - waialua359 [more]
Unread 28-06-2010, 16:18
MWB's Avatar
MWB MWB is offline
Building and building.
AKA: Marcus W. Byrd
FRC #3716 (WABots)
MWB is just really niceMWB is just really niceMWB is just really niceMWB is just really nice
Send a message via AIM to MWB
Re: pic: 2011 Drive Prototype
A few questions:
1. Are the cam tensioners any different than the standard 254/968 style? Based on their mount location it doesn't look any different, in which case there's not much point to keeping them "a secret".
2. Did you remember to set material properties on the compressor and CIMs? Right now you have 11 pounds in CIMs and 4.3 pounds in the compressor, which means everything else shown weighs only ~18 pounds?
3. What are your transmissions made of that you get them down to 1 pound? I'm curious. I've basically found through CAD that the only way to get a shifter in a similar application down to 1.01 pound would be to switch to suboptimal (as I've been told) parts, or like 1/8th delrin or something ridiculous like that. How'd you get this transmission to 1 pound?
If everything's as it seems and you made a 34 pound chassis that does all that, good job!
Well the cams method of turning are different, not the actual block.
Yes all the materials are set. The reason that it is so light is because the upper-structure is made of 1/16in aluminum
They are made of 1/4in Delrin and 7075 Aluminum
Marcus W. Byrd
Team 3716
Lead CAD/Design and Fabrication.
2992 with 5 motor 2011 Prototype Drive System 45Auto General Forum 4 22-04-2010 23:01
pic: 2826 Halonomic Drive Prototype Tyler Olds Extra Discussion 15 10-12-2009 22:38
pic: 1010 Drive system prototype joeweber Extra Discussion 10 24-08-2009 15:28
pic: 1885's Drive Train Prototype JesseK Extra Discussion 5 01-02-2009 02:11
pic: 213 - Drive prototype teaser Tyler M. Robot Showcase 10 07-01-2007 20:56
