Go to Post I suggested it in brainstorming, but then people threw things at me. Apparently there ARE bad ideas in brainstorming. - Kevin Sevcik [more]
Unread 01-07-2010, 14:53
Re: pic: 6 wheel drive train concept picture one
Snap rings are the best! They weigh nothing and are easy and quick to install.
I've seen Delrin, HDPE, and nylon guides successfully used in this application before.
Unread 01-07-2010, 15:10
ttldomination's Avatar
Sunny
I too am interesed about your gearbox attachment methods.
1648: 2013-2014
5283: 2015
Unread 01-07-2010, 22:28
kinghashbrown kinghashbrown is offline
Lead Designer and Team tri-captain
AKA: Joey Fisher
FRC #0176 (Aces High)
kinghashbrown is an unknown quantity at this point
I plan on replacing the front face of the gearbox with a plate that has all the holes and extends off and inch and a half to the left and right of the box. Four aluminum spacers will run from the plate to the 80/20, 1/4"-20 bolts will go through them and screw into t nuts in the 80/20 t slot profile. However I am somewhat concerned that if someone hits the center wheel it could cause the SS to move out of place. I haven't really worked much with 80/20 before, so I don't know if that is a legitimate concern.
p.s. Picture two will have this in it. It should be up tonight, right after my laptop is done making it.
pic: Simple Drive Train Concept JesseK Extra Discussion 5 09-01-2010 22:28
pic: 1683 Concept 8 Wheel Drive sdcantrell56 Extra Discussion 16 16-04-2007 14:22
pic: One Omni wheel drive done falconmaster Extra Discussion 2 11-01-2007 19:26
pic: 6 wheel drive train pick CD47-Bot Robot Showcase 3 14-04-2004 07:10
