Go to Post I bet if anyone took a look at the 118's Bill of Materials the only thing that would be on there is hard work and that's priceless. - rcmolloy [more]
Unread 01-07-2010, 18:08
MWB's Avatar
MWB MWB is offline
Building and building.
AKA: Marcus W. Byrd
FRC #3716 (WABots)
MWB is just really niceMWB is just really niceMWB is just really niceMWB is just really nice
Send a message via AIM to MWB
Re: pic: 2011 Drive Prototype
Originally Posted by CraigHickman View Post
Hm. Really?
- Cam actuated tensioners? Check.
- Self locking style cams? Check.
- 2x1 frame members surrounding semi-elliptical bearing blocks? Check.
- External cantilevered wheels? Check.
- Center wheel direct driven? Check.
- Two speed custom gearbox? Check.
- Belly pan for electronics, cut on a waterjet/laser? Check.
- Welded sheet battery box? Check.
I could keep going on. Are you SURE it's not a copy of the 254/968 system?
Ok #1 Its the concept that i copied, not the design. there are many differences in my design versus 254's. While the design was heavily inspired by 254, it is not a copy. What i did was i took the concept and adapted it to suit my own needs. The Belly pan's cut out pieces are different sizes, the bearing blocks are different dimensions, work a little differently and have smaller radiuses... Pretty much all the things that you listed were concepts not total designs. Anyways who hasn't used a 254 concept in their career in FIRST.
Marcus W. Byrd
Team 3716
Lead CAD/Design and Fabrication.
2992 with 5 motor 2011 Prototype Drive System 45Auto General Forum 4 22-04-2010 23:01
pic: 2826 Halonomic Drive Prototype Tyler Olds Extra Discussion 15 10-12-2009 22:38
pic: 1010 Drive system prototype joeweber Extra Discussion 10 24-08-2009 15:28
pic: 1885's Drive Train Prototype JesseK Extra Discussion 5 01-02-2009 02:11
pic: 213 - Drive prototype teaser Tyler M. Robot Showcase 10 07-01-2007 20:56
