Go to Post "well.. I think I underestimated the swine..." -Andy Baker - Joel J [more]
Unread 01-07-2010, 22:41
kinghashbrown kinghashbrown is offline
Lead Designer and Team tri-captain
AKA: Joey Fisher
FRC #0176 (Aces High)
kinghashbrown is an unknown quantity at this point
Re: pic: 6 wheel drive train concept picture one
We have used what are effectively plastic blocks to tension our drive chains for the past four years without any issues. We usually use oil impregnated nylon, turned on a lathe so that it has a lip sticking up where the chain will ride over it. This way the chain rollers are supported rather than the connecting plates.
This method of tensioning can be seen clearly on our 2008 robot, here. In that photo you can also see the use of UHMW Polyethylene chain guides, purchased from McMaster.
I think it's worth noting that I was a little skeptical of plastic tensioners and guides at first, but after seeing our 2008 robot run around with its ridiculous serpentine wrapping of the chain and no noticeable drag in the drivetrain, all of my worries vanished.
Thanks for the info. I found it helpful.
pic: Simple Drive Train Concept JesseK Extra Discussion 5 09-01-2010 22:28
pic: 1683 Concept 8 Wheel Drive sdcantrell56 Extra Discussion 16 16-04-2007 14:22
pic: One Omni wheel drive done falconmaster Extra Discussion 2 11-01-2007 19:26
pic: 6 wheel drive train pick CD47-Bot Robot Showcase 3 14-04-2004 07:10
