Go to Post The urge to compete tends to drive teams to hold the ideas close during the competition season, but the urge to contribute means they get publicized afterwards. - Alan Anderson [more]
Unread 03-07-2010, 22:33
rahilm's Avatar
rahilm rahilm is online now
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
Re: pic: Off-Season Kicker Design
Originally Posted by apalrd View Post
We used an anti-backdrivable window motor, and attached it to parts of a toughbox (1 stage). We made an assembly that, using a 2" bore piston, separated the gears in the direction of force, so the piston held the two gears together when not kicking. This was after we were unable to release a dog gear, even after greasing it and pulling it by hand. I don't know if there are any good pictures of it, but if you're at IRI, you can come to our pit and ask us about it.
In a nutshell: We un-mesh the gearbox by attaching the motor side to a plate that moves to pull the two gears apart.
I was thinking about this, and the way you guys did it inspired another thought for me:
Make a slot in the gearbox where that final gear is so that the gear can slide, and then have a pneumatic cylinder attached on either side of the shaft. When the pneumatic is at one end, the gear meshes. At the other end it disengages and you get a kick. That shouldn't take nearly as much force.
(The slot shouldn't be too hard to figure out. Just something following a line at a smaller angle than that of the line tangent to the pitch circle of both gears, right?)
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
pic: 1503's Off-Season Project Pat Fairbank Extra Discussion 28 31-12-2008 14:27
pic: Off season project joeweber Extra Discussion 19 31-12-2007 22:50
Help design off-season project efoote868 Chit-Chat 4 09-04-2007 09:19
pic: What we do in the off season. (2) Chuck Glick Chit-Chat 7 30-05-2006 11:06
pic: 226 Off-Season Gearbox Matt Reiland Robot Showcase 5 01-02-2005 20:53
