Go to Post one wrong move and you could end up capping one of the judges. that will pretty much ruin your chance at judges' award - Mike Ciance [more]
Unread 07-07-2010, 12:17
MCahoon MCahoon is offline
FRC #3826 (Sequim Robotics Federation)
MCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud of
Re: pic: Off-Season Kicker Design
Isolating the pot from the shaft (via a chain or belt etc) is certainly a solution, but not the only way.
If you use the pot to replace one of the shaft bearings then of course that's going to put unacceptable loads on the pot. But if you mount the sensor directly to the shaft (through a simple coupling) on the outboard side of one of the end bearings it will not bear the shaft loads.
Essentially what we did. We had a gear on the end of the winch shaft. That gear drove an idler shaft that had the pot attached to the end of it. The pot (and the encoder that replaced it) were not bearing any loading from the kicker.
pic: 1503's Off-Season Project Pat Fairbank Extra Discussion 28 31-12-2008 14:27
pic: Off season project joeweber Extra Discussion 19 31-12-2007 22:50
Help design off-season project efoote868 Chit-Chat 4 09-04-2007 09:19
pic: What we do in the off season. (2) Chuck Glick Chit-Chat 7 30-05-2006 11:06
pic: 226 Off-Season Gearbox Matt Reiland Robot Showcase 5 01-02-2005 20:53
