Go to Post Mmmm scrap used parts. Dismantle, find data sheets and have fun.:D - techhelpbb [more]
Unread 07-07-2010, 12:48
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: pic: Off-Season Kicker Design
We had a gear on the end of the winch shaft. That gear drove an idler shaft that had the pot attached to the end of it.
Sure, that's a good solution. But the point was it's also possible to mount the pot (or encoder) directly to the shaft through a simple in-line coupler on the end of the shaft. With that approach there would be no undue loads on the pot. It's not the direct connection to the shaft per se that causes the loading problem, it's if you try to use the pot in place of a load bearing.
pic: 1503's Off-Season Project Pat Fairbank Extra Discussion 28 31-12-2008 14:27
pic: Off season project joeweber Extra Discussion 19 31-12-2007 22:50
Help design off-season project efoote868 Chit-Chat 4 09-04-2007 09:19
pic: What we do in the off season. (2) Chuck Glick Chit-Chat 7 30-05-2006 11:06
pic: 226 Off-Season Gearbox Matt Reiland Robot Showcase 5 01-02-2005 20:53
