Go to Post I GET that FIRST is about more than winning on the field. BUT... ...it is my experience that the great programs of the FIRST world almost always build on a foundation of competitive robots. Success on the field begets success in other realms. - Joe Johnson [more]
Unread 19-07-2010, 16:14
Mike Schreiber's Avatar
FRC #0067 (The HOT Team)
Re: pic: 1625's 2010 Robot
Originally Posted by Zach O View Post
Awesome robot! I have a question. What did you use to continue lifting after time went off? Did you use the same thing as 67 did, or did you have another way to go about doing it?
Edit: Got the answer. A limit switch and gas shocks?
They used a set up very similar to HoT's. HoT used 4 200 lb gas shocks, Winnovation used 3 250 lb shocks. The most notable difference in the two systems is in the release. Hot had a mechanical release on a truck latch (I believe off an Impala, but don't hold me to that) so when they released their hanger if it didn't hit the bar before the buzzer the gas shocks would still release.
1625 had a limit switch on their new latch (now similar to RUSH's latch) that said when this limit switch is tripped use servo to release gas shocks. HoT therefore has a slight time advantage because they don't need power to release, but on the other hand they also need the bump.
There was also a difference in the method the teams compressed the shocks. Winnovation used a heavily modified cable winch and HoT built their own hand crank. Both systems are remarkably impressive and effective.
Zach if you have any other questions I have detailed pictures of both.
Kudos on a great bot 1625.
Mike Schreiber
Unread 19-07-2010, 16:23
ttldomination's Avatar
Sunny
If you don't mind me asking, can you post the pictures or upload them somewhere for the rest of us as well?
- Sunny
1648: 2013-2014
5283: 2015
Unread 19-07-2010, 16:33
Data Nerd
FRC #0079
- Sunny
I'll work with Mike to get the full res ones on Flickr. (Mike, shoot me a text message when you are done with classes for the day)
Unread 20-07-2010, 15:13
I'll get 'em up eventually, I need either a camera cord or a card reader neither of which I have with me at school (they're at home) so I'll see if someone around here has something or you guys will have to wait a few days till I go home.
I'll put them on Andrew's Flickr, mostly because I'm pretty sure he'll do it for me once I give him the pictures.
Mike Schreiber
pic: 548's 2010 robot Bjenks548 Extra Discussion 10 19-05-2010 21:40
pic: 1557's 2010 Robot gorrilla Extra Discussion 15 24-02-2010 02:06
pic: 1625's swerve module (better pic) Aren_Hill Extra Discussion 25 22-07-2008 19:14
pic: 1625's shooter ready to fire Aren_Hill Extra Discussion 24 19-06-2008 01:44
pic: 1625's arm control Aren_Hill Extra Discussion 9 15-10-2007 11:55
