Go to Post CD threads are supposed to be about something? - Tim Baird [more]
Unread 01-08-2010, 22:10
Re: Drop-center drivetrains: Why?
No problem.
I felt really, really bad not including "the math" supporting the claim, so here's a link to an excellent paper on the topic of drivetrains that explains all of the phenomena. It never specifically addresses the case of the 6 wheel drop, or what happens if you lower the sideways traction of one of your wheel sets (i.e. if you put omnis on one part of your drivetrain) but it shouldn't be too hard to see how a 6 wheel performs better than a regular drivetrain as a result.
If we're engineers, I feel we shouldn't be content with the what without the why...
http://www.chiefdelphi.com/media/papers/1443
Unread 01-08-2010, 22:48
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
ditto that !
Unread 02-08-2010, 02:53
We're not engineers, small correction. Statement is true otherwise.
Unread 02-08-2010, 07:33
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Simply put, without dropping the center wheels, drive motors rapidly go to stall current in turns.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 02-08-2010, 08:19
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Do a little more digging. A common questiont that many 6x6 drop center guys will ask is "How much drop are you using?". While a fair question, the same amount of drop will have various effects on different chassis. CG placement and Chassis stiffness, and overall goals/objectives play a big part into what is considered effective amounts of drop.
Unread 02-08-2010, 09:31
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
As an example, 95 has used dropped center designs when the robot did not have precise manipulators mounted on the chassis, where the robot rocking back-and-forth did not adversely affect controllability. On two robots that DID have bigger arms that needed to be controlled with precision we used omni wheels on the four corners so that the robot was more stable and the arm was easier to control.
EDIT: To avoid confusion, I am talking about a 6wd platform with two traction wheels in the middle, and omni wheels at each corner.
Unread 02-08-2010, 12:32
Originally Posted by JamesCH95 View Post
... On two robots that DID have bigger arms that needed to be controlled with precision we used omni wheels on the four corners so that the robot was more stable and the arm was easier to control.
Anecdotal evidence would suggest that rocking drive trains still maintain the maximum manipulator control aspect given a proper c.g. As an example from 2005, 254's robot had a rocking 6WD with a very long 2-PID arm. When fully extended the arm would shift the c.g. slightly, yet when it was down the tetras were easy to pick up because the c.g. stayed towards one side or the other when the robot was not accelerating.
Unfortunately it is exceptionally hard to integrate c.g. from scratch ahead of time; rough estimates are the best I've ever seen derived at the early stages of design. Since drive train is one of the three systems that MUST work (drive train, electronics, programming) in order to do anything effective in a game, most teams prototype like crazy on a pre-season prototype drive train. Additionally, finishing the production drive train early in the season is atypical of actuality for most teams.
Ergo a wise suggestion to anyone worried about c.g. shift on a rocking drive train is to have a pre-season prototype ready to go such that manipulators may be directly mounted to it during build season prototyping. This will give earlier estimates on c.g. and should produce constraints on shifting c.g. that may dictate where to put the 'heavy' elements (compressor, battery, drive train gear boxes, etc) on the production robot.
GitHub
Unread 02-08-2010, 14:48
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
For all of the analysis that could go into a chassis like that it is simpler to use omni wheels on the corners and be done with it. That frees up all the time and energy saved in chassis analysis for use in more unique challenges.
Unread 02-08-2010, 14:54
EricH EricH is online now
It's simpler, unless the game requires pointing in one direction for any length of time (like 2 seconds to unload a game object). The defensive robots love 6WD robots that have omnis on the corners, something about they're easier to knock out of position rotationally.
A pneumatic center wheel on a drop-center is actually a pretty good idea: you can fine-tune the drop a little bit to get exactly the characteristics you want, even between matches.
Unread 02-08-2010, 15:08
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Good point about the defense.
Changing pneumatic tire pressure would also change gearing and grip, but those might also be good things.
Unread 02-08-2010, 23:36
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
1276 built a launcher in 2008 with a 6 wheel drive with omnis in the corners. I was sure we would get knocked all over the place trying to launch, but it was never an issue. We would've done it again in 2009 were it not for the slippery floor, and the team disbanding in 2010.
That said, in 2008 there wasn't a lot of incentive to knock robots silly, so we may have just gotten lucky.
As a counterpoint to my own counterpoint, I can't think of many situations where if someone is trying to rotate you, you'd be much better off with the stickier wheels. In 2010 if someone was messing with you, you'd drive off before kicking the ball. In 2007, you were probably entangled in the Rack, so the squirrelyness (technical term) might help you swing around to another Spider. In 2006 if someone was pushing on you, it was probably enough to throw off your aim. Additionally, it cut way down on our distance (though our conveyor to our shooter and shooter wheels were all on one CIM, so this may have been less of an issue for others). In 2005, perhaps it could help you stick your ground for just an extra second, but this came turned out so offensively, I'd rather not be rocking back and forth with a 10 pound tetra 10 feet up in the air.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 03-08-2010, 08:35
Brandon Holley's Avatar
I don't know about your reasoning here. It seems in every instance you brought up that someone trying to rotate you is prohibiting you from completing your initial task. In your 2010 example instead of kicking the ball you drive away because someones "messing with you". In 2007 you are swinging from the initial spider your trying to cap to a different one because your being rotated. In 2006 being lined up and not moving was key for 90% of the shooters out there, obviously. In 2005 getting to where you needed to get to was absolutely key.
Not meaning to nitpick here, but the suggestions you make are all alternative maneuvers your team can make to offset being spun easily. In all those instances, I would much rather not be spun and complete the task my team wants to, than come up with a new game plan because someone is playing D on me.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 03-08-2010, 08:42
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
Make sure when discussing "performance" to use key words like traction, ability to hold ground, ease of turning, manuverability...
Saying "XYZ will perform better" in a thread like this can lead to misconceptions. Many of the parameters for manuverabilty and the ability to hold ones ground are in direct conflict.
Unread 03-08-2010, 18:24
Best Available Data
Perhaps you were blessed with better drivers than us. It just seemed that the vast majority of the time we were being defended, it was a better use of our time to leave and sneak to a different location rather than wiggle back and forth with someone slamming on us.
-Brando
Cory, we had issues with rocking and the dropped center wheel, but we may have dropped more than .1875, it's been a while. In 2006 when shooting from the floor, rocked one way we would make shots, rocked the other way they went high (or low). We also had some tracking issues with our dead reckoning autonomous.
Unread 04-08-2010, 08:11
We have (on more than one occasion) used a dropped a foot under the front or back of the robot to assist in turning. This raises one set of wheels off the ground.
For some of the other discussion, there is no substitute for practice.
A common joke among music professionals goes like this...
A person on a street in New York is asked "How do you get to Carnegie Hall?". The response is "practice, practice, practice!"
Al
WB9UVJ
www.wildstang.org
pic: Center Player Station and Ball Drop Wetzel Extra Discussion 2 08-01-2006 17:40
Center to Center Distance for 2002 Chaiphua and Cluster gear sanddrag Motors 1 20-07-2005 07:36
Omnidirectional drivetrains patrickrd Technical Discussion 21 11-10-2002 10:54
Drivetrains archiver 2001 14 23-06-2002 22:52
