Re: pic: 1640 Pivot Module
Guys,
The distance from floor to top of module is nearly the same for both our designs. (BTW, we do not use a coaxial drive, opting instead for motors in the module) We have run checks of current draw on the steering motors during a pushing match and found that without the bottom bearing (ours is near the floor) the motor current skyrockets as additional side load is applied to the bearings. It is unavoidable. Obviously, different bearing types produce different frictions, your mileage may vary. Without something to limit the side movement of the module, a strong robot is likely to move the bottom of the drive module at least a 1/4" or more if the wheels are sticky. Something has to give, and with both the steering and drive running in the assembly, something may bind and momentarily fail to perform as desired. One lost match can screw up your whole day. |
To Dillon Carey,
We used Labview for the programming. Since each wheel is independently driven and steered, the software development was not trivial. On the other hand, with a choice of crab and snake drive, and two different robot twist modes (around the drive-train centerpoint and around the possessed ball centerpoint), we have a remarkably agile and maneuverable robot. It was worth the effort. This is basically a fly-by-wire robot. |
If you would like any help with code or a copy of our how we programed our bot just send me a personal message. |
Brando,
We used needle thrust bearings to handle the thrust load. the delrin ring went around the bottom of the module, which had an aluminum ring on it. This ring was there only for extreme load situations. Like Al said without bottom support things tend to bind under extreme load. But I do believe with the correct bearing and support you can nearly remove the lower bearing without much increased turning friction under load. Ex: in a pushing match, if your module is supported enough to have almost no binding until your traction brakes then you should be able to get away without supporting the bottom of the module. |
| pic: Siri's Buttons. Thank You 1640. | JaneYoung | Extra Discussion | 6 | 21-07-2010 21:51 |
| pic: 1640's 2010 Pivot Assembly | Gdeaver | Extra Discussion | 8 | 10-02-2010 20:11 |
| pic: FRC 1640 2006 Robot | coastertux | Robot Showcase | 3 | 09-03-2006 13:42 |
| pic: Team 1640 - Lift Teaser | coastertux | Robot Showcase | 6 | 02-02-2006 16:11 |
| Team 1640 @ Chesapeake | coastertux | Regional Competitions | 0 | 20-03-2005 14:18 |
