Go to Post If mentors don't respect the students' desire to learn and take an active role in the construction, they're missing the point of FIRST. If students refuse to accept the knowledge and experience of the mentors, that's not independence - it's arrogance. - DB213parent [more]
Unread 04-08-2010, 15:38
Dillon Carey's Avatar
Dillon Carey Dillon Carey is offline
6wd swerve, it has been done
AKA: TinyHippo
FRC #1625 (Winnovation)
Dillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond repute
Re: pic: 1640 Pivot Module
Brando,
We used needle thrust bearings to handle the thrust load. the delrin ring went around the bottom of the module, which had an aluminum ring on it. This ring was there only for extreme load situations. Like Al said without bottom support things tend to bind under extreme load.
But I do believe with the correct bearing and support you can nearly remove the lower bearing without much increased turning friction under load. Ex: in a pushing match, if your module is supported enough to have almost no binding until your traction brakes then you should be able to get away without supporting the bottom of the module.
"More power 'till it breaks or you win."
- Keith Carey
pic: Siri's Buttons. Thank You 1640. JaneYoung Extra Discussion 6 21-07-2010 21:51
pic: 1640's 2010 Pivot Assembly Gdeaver Extra Discussion 8 10-02-2010 20:11
pic: FRC 1640 2006 Robot coastertux Robot Showcase 3 09-03-2006 13:42
pic: Team 1640 - Lift Teaser coastertux Robot Showcase 6 02-02-2006 16:11
Team 1640 @ Chesapeake coastertux Regional Competitions 0 20-03-2005 14:18
