Go to Post Stand up and cheer for yourselves and others. That is FIRST, don't change it. - Steve W [more]
Unread 18-08-2010, 01:07
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: paper: CAN Jaguar Speed Control with Current Limit
It seems to me that there wouldn't be enough bandwidth between the cRIO and the jaguars to implement this effectively, as I believe [kamocat]'s testing says roundtrip communication times are in the 10s or 100s of milliseconds, and current spikes will potentially be shorter than that.
While it may help against motors sitting in stall for long periods of time, I'm not certain if this will retain all the desired points of current control mode. Could definitely be worth testing, however.
--Ryan
FRC 766, 2015-, Mentor
Help with CAN bus closed-loop speed control RoboGuy Programming 16 14-04-2010 12:34
Gray Jaguar CAN closed-loop speed control Ether CAN 6 13-04-2010 23:10
CAN Jaguar Enable Control .vi Initial Encoder Position TonyP CAN 0 26-02-2010 19:23
jaguar speed control of mecanum wheels Ether Motors 7 05-02-2010 13:02
Can I control a victor/jaguar with an RC receiver Bruceb Electrical 3 30-12-2008 10:50
