Go to Post Is it weird we think speed controllers are sexy? - vivek16 [more]
Unread 18-08-2010, 12:01
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Re: pic: CAD exercise - 1640 Pivot Assembly with cut-away view of Pivot Module
Clem,
A very nice drawing, you sure are getting the hang of using Inventor. Do you have an exploded view worked out yet? Keep up the good work!
Al
WB9UVJ
www.wildstang.org
________________________
Unread 18-08-2010, 14:34
I like a lot of things about your modules this year. Two chain reductions instead of a transmission, the triangle gussets on the sides of the module for stability, the dead axle with extra nuts instead of spacers at the bottom, and using an axle as a structural member of your module. Nice job!
Unread 18-08-2010, 14:52
Is that #25 or #35 chain?
Unread 18-08-2010, 19:29
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
I am very surprised that you did not have trouble with the cantilevered side-load on the Denso motor shaft. The worm gear in that motor is a plastic gear captured only by the thin sheetmetal lid on the housing, and is not designed for any side-load whatsoever. You might want to consider supporting the end of that sprocket if you can. We have found that a 5/8" OD ball bearing fits nicely into the center hole of the plastic Denso adapter to provide end support.
I very much like the chain reductions and overall design of your module. Very similar to our own.
Unread 19-08-2010, 08:10
Gdeaver Gdeaver is offline
FRC #1640
Inventor was used to model the whole robot. The chains are #35. We have not had any problems with the steering motors from the sprocket not being supported on 2 sides. We have had major problems with the Denso window motors. The locking pins caused some serious drag when not run at full speed. We removed the locking pins and the denso motors worked much better in this steering application. Even with the pins removed, we had random motor shut down. We removed the jags and substituted victors. Since we went to victors we have not had any problems with the Denso units. Denso and jags do not mix. The over all design has worked very well. However we are working on several design tweeks in the off season. One thing that gave us problem were set screws constantly loosening. The next iteration will not rely on sets screws.
Unread 19-08-2010, 08:39
Brandon Holley's Avatar
I think we all learn this lesson once before we wise up and nix set screws from our designs. Its a right of passage of a FIRST team.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 19-08-2010, 09:12
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
That observation seems worthy of a tangential discussion. We haven't used window motors for anything lately, so I can't comment, but I'm very curious. Are there any other teams out there who had a similar (or contradictory) experience using them with Jaguars?
Unread 19-08-2010, 11:04
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
Indeed, in fact there's been a rather interesting discussion about it already, if you're interested. EDIT: Gary's got it.
Unread 19-08-2010, 11:05
FRC #1640
There is a thread on the Jag and Denso problem.
http://www.chiefdelphi.com/forums/sh...ad.php?t=83973
We have not responded to this thread since removing the locking pins. Even with the locking pins removed, we experienced random Denso shut down. For IRI we swapped out the jags for victors and the problem has disappeared. The window motors are great without the locking pins and victors. We have no hard data to help with why the Denso's overheat while under very light load with the jags. I think it has something to do with the high switching frequency of the jags interacting with the PTC causing it to self heat. I would like to see First allow the removal of the locking pins. Its easy and improves the performance of the motors. However, The bypassing or removing the PTC is much more questionable. It's an actual modification of the motor. So if you use the window motors, use victors.
Unread 19-08-2010, 16:33
Software Architect
Thanks. I don't regularly follow the Motors forum, so I didn't know so much attention had already been applied to the subject.
Unread 19-08-2010, 21:39
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
We have not had any problems with the cantilever loading on the window motor sprocket. We are still using the original (4) window motors after (6) competitions (on & off-season) and (4) demos. We've got (L&R) spares, but have not needed to replace any originals yet.
We embed a magnet in the end of the sprocket. A Cherry absolute magnetic encoder is mounted on the plate below the sprocket. This encoder provides information on the sprocket angle and (since the drive sprocket on the motor and the driven sprocket on the pivot are both 15T) therefore the pivot angle. This makes mounting the bottom end of the drive sprocket problematic.
Regarding building chains in Inventor, I have a process which works well (albeit a little tedious). I will write this up (it'll be short).
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
Unread 19-08-2010, 14:59
You could definitely get away with #25 chain on the initial reduction, and possibly on the final reduction as well.
Unread 20-08-2010, 03:44
Aren_Hill's Avatar
Build Nifty Things
I can picture it now
pit visitor: "Why'd you use #35 chain?"
team member "less links to CAD...."
A guy who likes robots.
pic: 1640 Pivot Module Clem1640 Extra Discussion 11 05-08-2010 00:47
pic: 2228 Cougar cut on to sheetmetal (CAD) jamie_1930 Extra Discussion 11 09-05-2010 19:29
pic: 1640's 2010 Pivot Assembly Gdeaver Extra Discussion 8 10-02-2010 20:11
pic: Swerve Module Concept (View 2) Dave McLaughlin Extra Discussion 5 17-06-2009 00:15
pic: Swerve Module Concept (View 1) Dave McLaughlin Extra Discussion 15 16-06-2009 22:36
