Go to Post Just get a nice big box of maraschino cherries and a cup of coffee and settle yourself down for a fun read. You'll be amazed at the ideas that you are going to have pop into your head. - JaneYoung [more]
Unread 21-08-2010, 11:58
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: paper: CAN Jaguar Speed Control with Current Limit
Thanks for your comments Ryan.
If the concern is the circuit breaker in the Jag, take a look at the Jag in current-control mode with cRIO controlling speed.
If the concern is motor damage due to overheating, the thermal cutoff approach might provide some protection.
If the concern is traction control, using the Jag in speed-control mode and providing a current limit in the cRIO might be the best thing to try.
Help with CAN bus closed-loop speed control RoboGuy Programming 16 14-04-2010 12:34
Gray Jaguar CAN closed-loop speed control Ether CAN 6 13-04-2010 23:10
CAN Jaguar Enable Control .vi Initial Encoder Position TonyP CAN 0 26-02-2010 19:23
jaguar speed control of mecanum wheels Ether Motors 7 05-02-2010 13:02
Can I control a victor/jaguar with an RC receiver Bruceb Electrical 3 30-12-2008 10:50
