Go to Post *be there or be triangle, circle, square - PVCpirate [more]
Unread 23-08-2010, 18:23
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: pic: 221 Robotic Systems Swerve Demo Bot Steering Feedback
Originally Posted by Joe Ross View Post
They do have a deadband at the rollover point, the rollover isn't a perfect "sawtooth". We've used Vishay 357s which after the rollover remain zero for 10-20 degrees. These appear to have similar specs.
If you can live with the deadband, we very much like them. Continuous pots have been much more robust then any encoder we've used.
So could you explain how you deal with the dead band in your logic?
Unread 23-08-2010, 18:30
Nikhil Bajaj Nikhil Bajaj is offline
MATLAB Fan
Nikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond repute
Send a message via AIM to Nikhil Bajaj
As an alternate sensor, one might consider the US Digital MA3, which has a much smaller dead band (it is pretty minuscule.) They are a little more expensive, though, at around $40+. However, you can get a ball-bearing version that can sustain higher rotational speeds.
http://www.usdigital.com/products/en...ary/shaft/ma3/
This is what we like to use for certain things on 461. I found out about them when asking some folks on 469 about their swerve drive a few years back.
I guess my method of dealing with dead bands is avoiding them entirely if possible!
Unread 28-08-2010, 17:31
Gdeaver Gdeaver is offline
FRC #1640
I noticed that the sprocket on the steering drive is not the same diameter as the sprockets on the pivot modules. That combined with the dead band of the potentiometer would lead to some tough programing problems. I don't see any indexing on the steering system. So I want to know how are you guy's handling these problems? We used the window motors also. We have one for each module. Our steering sprockets are 1:1, so the value from the sensor always matches wheel orientation though 360 degrees. As to absolute rotary position sensors, I have not found any company that makes a classical potentiometer that has 360 degree mechanical and electrical ratings. The US Digital MA3's mentioned would be good for this application. We used the Cherry AN8 series. The Cherry AN8's are IP67 and automotive qualified. By being Automotive qualified you gain reverse polarity protection and higher ESD protection. Some teams have had problems with MA3's and ESD. They also are 0 to 5 volt and the out put is sloppy at the rails. The AN8's are 0.5 to 4.5 volts and have a sharp saw tooth slope.
Unread 30-08-2010, 21:37
The sloppiness of the MA3's have been annoying, and the fear of ESD has bothered me (but never affected us). What do the AN8 costs?
Unread 30-08-2010, 22:15
FRC #1640
The AN8's run about 40$ depending on the supplier. The AN8's come with a magnet assembly but it would not work in our use. We mounted a 15 tooth #35 sprocket on to the window motor and then mounted a 1/2" x 1/8" diametrically magnetized neodymium magnet on top of the sprocket. The Cherry sensor was then mounted 2.5mm away from the magnet. Look at the picture in this link.
http://wiki.team1640.com/images/thum...0124_csm_2.jpg
You'll also need the matching Delphi connector to make a cable for it. There are getting to be more and more sensors of this type in the market. Many are much more expensive.
Unread 30-08-2010, 22:17
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Looks to be about the same as the MA3. http://www.mouser.com/Sensors/Motion...rd=aN8&FS=True
We don't use crab drive. We've used continuous rotation pots instead of encoders for odometry.
I'd also be interested in hearing how 221 Robotic Systems dealt with the deadband in this application.
Unread 31-08-2010, 08:29
ajlapp ajlapp is offline
AKA: Anthony Lapp
The short answer is that we don't currently deal with the dead band.
Our first focus was developing the three driving modes; tank, crab and monster truck steer.
Our wheel rotation is currently limited to 75 degrees in either direction from neutral....this is plenty good for monster truck steer.
Anthony Lapp
FIRST Engineering Mentor
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Unread 31-08-2010, 20:41
BEEKMAN BEEKMAN is offline
AKA: Brendan McLeod
FRC #0190 (Gompei and the Herd)
BEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to behold
Was this the one on demo at IRI? If so, have you been able to control the jaguars with the Arduino yet?
WPI Robotics Engineering & Mechanical Engineering Class of 15
iRobot Mechanical Engineering Intern
Unread 02-09-2010, 18:31
AKA: Anthony Lapp
This is the unit from IRI.
We already control the Jaguars using the Arduino via pwm. We would like to add CAN communications using a 2CAN device but we haven't worked on this yet.
Its on the short list.
Anthony Lapp
RobotOpen
pic: Team 221 LLC. - Wild Swerve Module ajlapp Extra Discussion 77 06-11-2009 17:33
pic: Wild Swerve Demo Chassis ajlapp Extra Discussion 12 17-10-2009 08:09
pic: Revolution Co-Axial Swerve Module - Team 221 LLC. ajlapp Extra Discussion 10 31-08-2009 15:28
pic: 1726 Demo Bot s_forbes Extra Discussion 6 27-06-2007 12:56
pic: Vex demo bot Eldarion Extra Discussion 6 16-04-2007 16:54
