Re: pic: 221 Robotic Systems Swerve Demo Bot Steering Feedback
As an alternate sensor, one might consider the US Digital MA3, which has a much smaller dead band (it is pretty minuscule.) They are a little more expensive, though, at around $40+. However, you can get a ball-bearing version that can sustain higher rotational speeds.
http://www.usdigital.com/products/en...ary/shaft/ma3/ This is what we like to use for certain things on 461. I found out about them when asking some folks on 469 about their swerve drive a few years back. I guess my method of dealing with dead bands is avoiding them entirely if possible! |
I noticed that the sprocket on the steering drive is not the same diameter as the sprockets on the pivot modules. That combined with the dead band of the potentiometer would lead to some tough programing problems. I don't see any indexing on the steering system. So I want to know how are you guy's handling these problems? We used the window motors also. We have one for each module. Our steering sprockets are 1:1, so the value from the sensor always matches wheel orientation though 360 degrees. As to absolute rotary position sensors, I have not found any company that makes a classical potentiometer that has 360 degree mechanical and electrical ratings. The US Digital MA3's mentioned would be good for this application. We used the Cherry AN8 series. The Cherry AN8's are IP67 and automotive qualified. By being Automotive qualified you gain reverse polarity protection and higher ESD protection. Some teams have had problems with MA3's and ESD. They also are 0 to 5 volt and the out put is sloppy at the rails. The AN8's are 0.5 to 4.5 volts and have a sharp saw tooth slope.
The AN8's run about 40$ depending on the supplier. The AN8's come with a magnet assembly but it would not work in our use. We mounted a 15 tooth #35 sprocket on to the window motor and then mounted a 1/2" x 1/8" diametrically magnetized neodymium magnet on top of the sprocket. The Cherry sensor was then mounted 2.5mm away from the magnet. Look at the picture in this link.
http://wiki.team1640.com/images/thum...0124_csm_2.jpg You'll also need the matching Delphi connector to make a cable for it. There are getting to be more and more sensors of this type in the market. Many are much more expensive. |
I'd also be interested in hearing how 221 Robotic Systems dealt with the deadband in this application. Last edited by Joe Ross : 30-08-2010 at 23:09. |
Our first focus was developing the three driving modes; tank, crab and monster truck steer. Our wheel rotation is currently limited to 75 degrees in either direction from neutral....this is plenty good for monster truck steer. |
Was this the one on demo at IRI? If so, have you been able to control the jaguars with the Arduino yet?
We already control the Jaguars using the Arduino via pwm. We would like to add CAN communications using a 2CAN device but we haven't worked on this yet. Its on the short list. ![]() |
| pic: Team 221 LLC. - Wild Swerve Module | ajlapp | Extra Discussion | 77 | 06-11-2009 17:33 |
| pic: Wild Swerve Demo Chassis | ajlapp | Extra Discussion | 12 | 17-10-2009 08:09 |
| pic: Revolution Co-Axial Swerve Module - Team 221 LLC. | ajlapp | Extra Discussion | 10 | 31-08-2009 15:28 |
| pic: 1726 Demo Bot | s_forbes | Extra Discussion | 6 | 27-06-2007 12:56 |
| pic: Vex demo bot | Eldarion | Extra Discussion | 6 | 16-04-2007 16:54 |
