Go to Post We can't all be Dean. But with the right attitude and preparation, we can make careers out of our passions. - Richard Wallace [more]
Unread 31-08-2010, 16:16
kajeevan kajeevan is offline
FRC #0188 (blizzard)
kajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud of
pic: 6WD Sheet Metal
Unread 31-08-2010, 16:20
Re: pic: 6WD Sheet Metal
Looks like a good start.
In the past running the math on our drives, with 4 CIMs (and accounting for efficiency losses), there seems to be a large decrease in acceleration right around the 16.5/17 fps point. You should throw your numbers in JVN's calculator and see if you like the performance.
Also, minor nitpick here, but why two different pocketing styles? It'd look a whole lot sleeker if it was all angles versus half and half.
I like the more "complete" design than is usually posted; battery box, electrical board, tensioners, etc... Attention to these details is key for a successful base.
Unread 01-09-2010, 00:11
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
A FIRST field is approximately 34 feet wide and 57 feet long.
I think Adam is right. Watch videos from 06, 07, 08, and 10 and figure what the average straight full speed driving distance is.
Likely you'll find that your average driving distance is only around 10-20 feet. With your gearing, you'll never come close to hitting top speed and you'll get pushed around easily.
We've found 10-13 FPS to be the sweet spot in FIRST. Even overdrive rarely exceeded what that could provide because of all the traffic jams, etc.
Unread 01-09-2010, 00:32
I find it useful to see what speeds the best teams use for what situation...
http://www.team254.com/frc/robots
254 shifts to a max of 14-16fps. 2008 being the only exception.
But of course consider their specific drivetrain.
Unread 01-09-2010, 00:35
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
The spread between gears seems way too high. You can do the math and figure out at what point you break traction with 4 CIM's and a given wheel/mass combination, but it's probably somewhere around 6.5-8 FPS. 4.5 fps is agonizingly slow compared to most FRC bots of the last 5 years or so.
2001-2004: Team 100
2006-Present: Team 254
Unread 03-09-2010, 19:02
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
Nice touch with the sides, I agree with the above post, I would like to see the theme consistent on the inside pieces, the sides look much more cool. I am sure, however, that this is not a huge worry. I like the overall layout, but I feel you will be a bit disheartened at that gear ratio. Good job, keep up the great work.
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
pic: sheet metal 6WD kajeevan Extra Discussion 23 23-06-2010 10:20
pic: WCD Sheet Metal Concept Chassis GarrettF2395 Extra Discussion 22 20-05-2010 16:33
pic: Sheet Metal Drivetrain Jacob Paikoff Extra Discussion 14 30-04-2010 11:21
pic: GUS Team 228's 6WD Sheet Metal Prototype Chassis artdutra04 Extra Discussion 14 02-01-2009 02:11
[OCCRA]: Bending Sheet Metal troy_573 OCCRA Q&A 1 19-09-2005 22:27
