Go to Post Fire and smoke are great if you're into Battlebots, but we like to avoid them in FIRST competitions. - [more]
Unread 19-09-2010, 20:30
Re: pic: Staged Double Vertical Suspension
Forget the staged part; this is quite impressive. Good job!
GitHub
Unread 20-09-2010, 01:13
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Staged or not, that is quite awesome.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 20-09-2010, 22:39
Basel A's Avatar
Basel A Basel A is online now
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Thanks! I'd like to note that when I was hanging, there was about 500 pounds all on our two solid aluminum hooks, and there's nary a dent. In retrospect, that would've been a good spot for some lightening holes.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 20-09-2010, 23:10
Those side hanger attachments look very, very bent. Did the mechanism take the loads well? Would it have worked repeatedly?
Unread 20-09-2010, 23:26
Basel A's Avatar
AKA: @BaselThe2nd
The one on the left was not bent at all.
The one on the right, however, is. That happened when 1718 suspended. I suspect is was because their mechanism was a bit too tall, but it could have just been a moment-exertion issue.
I will note that while it bent, it did not break. Even after 1718 was removed, 27 suspended successfully without any further bending.
Would it have worked repeatedly? I am inclined to say yes, but really I'm not sure. As I said, there was another suspension without further bending. That specific bend may have been a "freak" incident or just a result of 1718's mechanism.
I do believe it would have worked multiple times in usage with 27, 33, and most other "strongman" vertically hanging robots. It was never tested with "driving up" 'bots such as 2056.
-Paul Copioli
Unread 21-09-2010, 16:31
Craig Roys's Avatar
Craig Roys Craig Roys is offline
Coach - Team 1718
FRC #1718 (The Fighting Pi)
Craig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond repute
Actually I think it happened because our bumper hung up on your bumper momentarily, and when it released there was a jolt which caused the bend. This is just a guess, but I think if we had lifted smoothly, instead of catching bumpers, the bend wouldn't have happened. I was a little nervous when it initially happened, but Clint was yelling to keep lifting so we did. It was pretty impressive to see - would've been really great to see during a match!
2016 Waterford District - Semifinalists and Entrepreneurship Award Winner!
2016 Troy District - District Winner and Chairman's Award Winner!
2016 MI State Championship - State Champs with 27, 67, and 6086 and Entrepreneurship Award Winner!
2016 FIRST Championship - Carson Field Quarterfinalists
pic: Robot suspension joeweber Extra Discussion 11 15-01-2010 20:32
pic: Air Suspension joeweber Extra Discussion 23 30-12-2009 13:04
pic: 6 wheel suspension joeweber Extra Discussion 16 13-11-2008 18:22
pic: FRC 1726 suspension MrForbes Extra Discussion 4 22-12-2006 15:57
pic: vex suspension psyco_klown Extra Discussion 9 14-11-2006 22:18
