Re: pic: Staged Double Vertical Suspension
Staged or not, that is quite awesome.
Thanks! I'd like to note that when I was hanging, there was about 500 pounds all on our two solid aluminum hooks, and there's nary a dent. In retrospect, that would've been a good spot for some lightening holes.
Those side hanger attachments look very, very bent. Did the mechanism take the loads well? Would it have worked repeatedly?
The one on the right, however, is. That happened when 1718 suspended. I suspect is was because their mechanism was a bit too tall, but it could have just been a moment-exertion issue. I will note that while it bent, it did not break. Even after 1718 was removed, 27 suspended successfully without any further bending. Would it have worked repeatedly? I am inclined to say yes, but really I'm not sure. As I said, there was another suspension without further bending. That specific bend may have been a "freak" incident or just a result of 1718's mechanism. I do believe it would have worked multiple times in usage with 27, 33, and most other "strongman" vertically hanging robots. It was never tested with "driving up" 'bots such as 2056. |
Actually I think it happened because our bumper hung up on your bumper momentarily, and when it released there was a jolt which caused the bend. This is just a guess, but I think if we had lifted smoothly, instead of catching bumpers, the bend wouldn't have happened. I was a little nervous when it initially happened, but Clint was yelling to keep lifting so we did. It was pretty impressive to see - would've been really great to see during a match!
| pic: Robot suspension | joeweber | Extra Discussion | 11 | 15-01-2010 20:32 |
| pic: Air Suspension | joeweber | Extra Discussion | 23 | 30-12-2009 13:04 |
| pic: 6 wheel suspension | joeweber | Extra Discussion | 16 | 13-11-2008 18:22 |
| pic: FRC 1726 suspension | MrForbes | Extra Discussion | 4 | 22-12-2006 15:57 |
| pic: vex suspension | psyco_klown | Extra Discussion | 9 | 14-11-2006 22:18 |
