Go to Post the truth is that a 'bot is only as complicated as you make it. - RogerR [more]
Unread 26-09-2010, 19:57
Data Nerd
FRC #0079
Re: Using Multiple Kinds Of Motors
Originally Posted by davidthefat View Post
You do make a great point, one great example is the Shake Weight... Its useless.
Now if I wanted to innovate what would be the best thing to innovate? Depending on the game, I would have to talk to my team about it. Most will think I am crazy, but I got to say, I can make a big impact by getting the new people on my side. I really wanna be crazy this year, have a blast while making a non relevant robot. I want people to way "WTF is that?" kind of response and then kick $@#$@#$@# at the competitions. I really want to move away from the traditional chassis too, maybe having a triangular pyramid?
Dave, have you ever considered that perhaps having a rock solid drive system would be beneficial to something complex? Perfection of a system comes not when you can add nothing more but instead when you can remove nothing. As you said, you are a programmer, as a programmer you aren't terribly familiar with mechanical systems (this is an assumption). Perhaps you should start by figuring out what you can remove from last years drive train to make it better. This would allow you to learn more (which will help you in the future when you show us your awesome new drive system) and help your team because a better drive system is ALWAYS a good thing.
Using vars across multiple .c files Smithvillefirst Programming 6 02-02-2006 20:29
Using multiple controllers SFXSARNIA Technical Discussion 1 12-01-2006 14:07
Using multiple robots at a display? Adam Richards Control System 5 02-04-2005 12:44
Multiple Motors phrontist Motors 12 21-06-2004 23:05
Multiple-Motors echos Motors 8 11-01-2004 17:34
