Go to Post It's kind of magical how I went from legos to replacing most of the iron in my blood with aluminum, and all thanks to my elementary school science teacher. - Astrokid248 [more]
Unread 04-10-2010, 09:40
Greg McKaskle Greg McKaskle is offline
FRC #2468 (Team NI & Appreciate)
Greg McKaskle has a reputation beyond reputeGreg McKaskle has a reputation beyond reputeGreg McKaskle has a reputation beyond reputeGreg McKaskle has a reputation beyond reputeGreg McKaskle has a reputation beyond reputeGreg McKaskle has a reputation beyond reputeGreg McKaskle has a reputation beyond reputeGreg McKaskle has a reputation beyond reputeGreg McKaskle has a reputation beyond reputeGreg McKaskle has a reputation beyond reputeGreg McKaskle has a reputation beyond repute
Re: pic: Daisy Bell Going Over The Bump
The official shock rating of the cRIO and its modules is 50G's. Again, not that difficult to attain when the robot has no suspension. As a pretty predictable indication, the clip on the modules releases at over 50. Clearly the cRIO will often take more, but has not been validated or rated over 50g.
Commenting on team 704's experiences in Dallas, I visited their pits a number of times as their robot was amazingly robust, was catching lots of air, and disabling as a result. Early indications were that the zero-config button on the front of the black bridge was being pressed as the bridge hit the bottom or side of their lexan sleeve they made for it. After modifications so that wouldn't happen, the problem persisted. Apparently the PCB within the bridge was able to move and internally press the button. A replacement bridge had not issues with this, and the original may have been due to internal damage due to previous hits.
Greg Mckaskle
pic: Team 1538's 2010 Robot - Daisy Bell Jon Jack Extra Discussion 14 09-03-2010 09:47
Team 2669 going over the bump Tottanka Robot Showcase 3 21-02-2010 15:31
FRC488 Driving Over the Bump Madison Robot Showcase 27 03-02-2010 04:40
2481 Drives Over the Bump with Mecanum Wheels kylelanman Robot Showcase 13 02-02-2010 00:53
Over the bump or under the tower quinxorin Rules/Strategy 44 18-01-2010 14:17
