Go to Post If you are stupid about this and violate the rules, and thereby cause your alliance to lose a match, then your alliance partners will gang up on you and violate your robot. - dlavery [more]
Unread 04-10-2010, 09:52
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: pic: Daisy Bell Going Over The Bump
Originally Posted by Greg McKaskle View Post
....As a pretty predictable indication, the clip on the modules releases at over 50. Clearly the cRIO will often take more...
Wow. We had to glue our modules in to prevent this, as during testing our robot almost killed itself since it lost the analog module (it had no way of knowing it had lost its analog inputs, as they were within normal ranges). (And we don't go over violently). Maybe it had something to do with mounting the cRio sideways, so the modules face to the back of the robot instead of up?
As for the bridge, we had issues at Kettering, so we duct-taped the connections A LOT, and found that mounting it so the button is on the side instead of the top helped too.
Kettering Motorsports
pic: Team 1538's 2010 Robot - Daisy Bell Jon Jack Extra Discussion 14 09-03-2010 09:47
Team 2669 going over the bump Tottanka Robot Showcase 3 21-02-2010 15:31
FRC488 Driving Over the Bump Madison Robot Showcase 27 03-02-2010 04:40
2481 Drives Over the Bump with Mecanum Wheels kylelanman Robot Showcase 13 02-02-2010 00:53
Over the bump or under the tower quinxorin Rules/Strategy 44 18-01-2010 14:17
