Originally Posted by JB987
One thing to consider regarding use of a single belt per side...if you do have a very rare belt failure your bot will basically be dead on the field while use of two belts per side still allows decent mobility should one belt fail on a given side. Good for you to consider using a belt though...987 switched 3 years ago to belts and loves them.
Definitely worth considering, though it's also worth noting that a direct driven center wheel can alleviate this problem somewhat.
Glad to hear some other teams have been using belts very well!
